| Stralis 430 EDC fault; Stralis 430 EDC fault | |
| Tweet Topic Started: Feb 18 2013, 02:33 PM (8,112 Views) | |
| Turbostar | Feb 18 2013, 02:33 PM Post #1 |
Iveco Stralis 430 losing power and edc light comes on flashed up the code 2f . when i checked the engine diagnostics the full code was DTC - 2F - FMI - 02 - , The vehicle has been to my Iveco dealer but they dont seem to have a clue . anyone with the iveco fault codes shed any pointers for me. Regards Jeff |
| Vector | Feb 28 2013, 10:12 PM Post #2 |
What's the crack man. F2 has to do with the turbo VGT. Here is a test you can do. Tilt the cab. Go over to the left hand side of the engine. Look at the turbo there is an air actuator in the middle of the turbo. Get another person to start the engine. The actuator should move down and then back up to its resting position. If not possible broken wire at the bend from bulkhead down to the air solenoid for the VGT. Let me know how ya get on. |
| Turbostar | Mar 21 2013, 04:06 PM Post #3 |
Did the turbo test and that seemed ok , Changed the vgt air solenoid valve at the front of the engine and that cured the problem , Thanks for your help. |
