| Pto Problem; 7.5 TONNE DROPSIDE | |
| Tweet Topic Started: Feb 21 2013, 09:48 PM (1,697 Views) | |
| mroosters | Feb 21 2013, 09:48 PM Post #1 |
hi i am having a bit of a problem with my gear pto pump , i have an iveco 75E15 1997 model 5 speed and i have a hiab 052 crane on it , the gear pto pump has sheared of at the 3 bolt fixing so it is buggered now, its a 6 spline and clockwise rotation .. I have been given one of a friend exact same pump 3 bolt fitting but it has a counter clockwise rotation arrow ! I have been told if i change the 2 pipes around in and out it should do the same job ? is this correct .. also i looked on the internet to buy one and there is a few different specs ie- 34cc , 42cc ,82 cc and i dont know what these mean so i cannot order one from there until i can find out what the specs i need , can anyone help thanks les |
