2008 daily rear hub seal
Topic Started: Feb 23 2013, 05:27 PM (1,579 Views)
jackwdwyer
Hi. Does any one know how the halfshaft is seperated from the rear hub? Im trying to change the seal as is leaking onto the disc. There is no hub nut or any obvious way of seperating them. I have removed the hub from the axle by taking out the 10mm hex bolts.
Thanks, Jack.
Remove all the 10mm hex nuts half shaft should slide out,then in front of you should be 65mm(I Think) nut, remove lock tab undo nut and the rest is self explanitary. On mine the seals are in the bearings replaced both problem solved. Paul
