O/s/r side light out; Problem with o/s/r side light, warning light on dash
Topic Started: Feb 25 2013, 11:09 PM (759 Views)
Jaytee1
Hi, I'm new to these forums, and new to Iveco. I recently purchased a 2008 35s12 panel van, and have a warning light on the cluster along with the message check brake light, check side light.
The brake lights work ok, but the o/s/r side light is out. I have checked the bulb, all ok. I have no 12 volt positive on the yellow wire feeding the light cluster (I have found this wire has been pinched between the cluster and chassis at some point, baring the cable, but no fuses have blown)
The van does have a tow bar which I will remove at some point as its been wired using scotch locks, which I detest!
Can anyone help?
Many thanks, Jason
