2006 75 E 17 Starting Problem; FAULT SYMBOLS
Topic Started: Mar 4 2013, 05:50 PM (1,714 Views)
lmvans
I have a starting problem with my 2006 Euro Cargo only happens when switched off at normal working temperature & left for 10 - 15 minutes then engine wont turn over & displayes Exclamation mark within a circle with an arrow & Yellow Triangle & red circle with exclamation marks also seat belt sign sometimes , Wait another 5 minutes and starts no problem , Always starts from hot or cold no problem , Owner Driver would appreciate any help with diagnosing problem :(
When the engine fails to start press the clutch pedal, if it starts then reversing sensor is fault.
Also the green wire with the code 8888 which comes from EDC and goes to the starter solenoid may be damaged.
