Wing mirror indicator
Topic Started: Mar 16 2013, 04:27 PM (4,042 Views)
u8myufo
Well it has to be said that a Monkey could have designed it better imho. Anyhow I want to replace the indicator bulb on the N/S mirror, seing as there appeared to be a small gap between the clear plastic cover and the mirror shroud I gently prised it open. Wrong move :o clear cover cracked off, well it came off clean so I should be able to superglue it back again. So it looks like I need to take the lower convexed mirror out to gain access to the bulb.Ok, so how do I go about that without further damage?
Thanks
I think you heat the lower mirror with a hair dryer or similar to soften the adhesive, and then use a suction cup (like for handling glass) to gently pull it off.
I'm sure someone will confirm this is correct shortly...
Forester
There's a good description in the forums here:
http://ivecoforums.com/topic/8736663/1
For some reason the search tool on the website didn't find it...
Careful with the mirror glass - it's really thin and easy to break.
Let us know how you get on :)
Sorry, the search is currently broken, zetaboards are meant to be fixing it...
u8myufo
Thanks guy`s the link worked ok. Well as I cannot seem to find any specific tool out there I will give it a go with the suction plate for the SatNav.
discoverer6
Here is the thread I initiated with the same question, with the outcome.
http://ivecoforums.com/topic/8844919/
I hope this helps.
