| Stralis Valve Clearances | |
| Tweet Topic Started: Apr 3 2013, 06:33 PM (4,197 Views) | |
| steve_c47 | Apr 3 2013, 06:33 PM Post #1 |
Hi Does anyone know what the valve clearance gap & Injector Gap is for a Stralis 440S54 (06 Reg) & also which is the best way to set the engine to check the gap initially. Any help would be grateful Thank You |
| Jlwf1981 | May 16 2013, 09:17 PM Post #2 |
Hi mate yeah but it is quite in depth and a little bit of mechanical back ground is needed, the procedure is very difficult for first timers and critical for good fuel consumption. Reply and I can help cheers joe cursor 13 |
| steve_c47 | Jun 1 2013, 07:33 PM Post #3 |
Hi, i've got plenty mechanical knowlege, mainly I don't know what the gaps should be. Cheers Ru based in the north east? |
