75E16 AsTronic
Topic Started: Apr 30 2013, 08:48 PM (1,255 Views)
cieranc
Went out to a 60 plate EuroCargo 75E16 today. Started and ran fine, would select a gear but wouldn't drive.
Had BCM and a transmission light lit on the dash. Texa connected then cut out because me laptop went flat (left the inverter/charger in the garage :unsure: ).
Checked all the obvious stuff but couldn't read the codes - is there a way to read the codes off the dash?
You can surf through the cluster menu through the buttons on the steering wheel, or on older models through the right rubber button on the cluster.
The instruments cluster must be "Highline" version!
