cab; will a cab off a facelift fit an older cargo
Topic Started: May 11 2013, 07:47 AM (1,468 Views)
ajs
^o) will a cab off a 2004 eurocargo fit a 97 chassis
Difficult to say... at first glance the cab is the same, but may differ some detail, like cutouts or mounting holes, which may be in addition to, or missing. These small details can ruin your project.
The 2004 cabin has a different part number!
cieranc
Measure the floor height.
Usually on newer cabs, the floor inside is flatter (no engine hump), this makes for a more ergonomic cab for the driver, but means the cab is mounted higher on the chassis to clear the engine.
Older cabs usually sit lower on the chassis but have an engine hump through the middle of the cab floor..
aidan
hi
Even if the cab will physically fit on the mounts, the electrics are going to make this a nightmare job.
aidan
