ford iveco cargo 0811
Topic Started: May 11 2013, 10:41 AM (1,583 Views)
tony123
Hi, I just bought a G reg ford iveco cargo 0811, 6kcc 5speed box, and in mint condition for age, however the speed is restricted I beleve the gear box is lower speed, i.e at 3000 rpm max speed is 52mph, is it possible to get and fit a gearbox capable of 70mph?
I did own c reg layland road runner 6kcc 5speed and that could do 73mph at 3000rpm, so i am thinking uprated gearbox for the ford,
Thanks for any help
The gearboxes, at that time, had the last speed gear ratio of 1 (so-called direct drive), even if they have 4 - 5 or 6 speed. To increase the vehicle speed you must change the gear ratio from the rear axle.
tony123
thanks for info,
Is this easy to do? What about costs for a garage to do? as just read some other forums, some people have had same thing, the gearings have been changed from the factory settings.
Edited by tony123, May 11 2013, 11:47 AM.
