White Toxic Smoke Visible From Space; 35S12 , 05 REG , 187000 MILES . VERY BAD SMOKING HABIT
Topic Started: May 22 2013, 12:31 PM (1,985 Views)
bromspaintedstuff
Hello
Can anyone help me
My much loved 35 s12 van has developed a very bad smoking habit , once the engine has warmed up the engine chucks out large plumes of white toxic smelling smoke when pulling away from a junction after idling .
I thought it might be the oil seals in the turbo , I disconnected the air pipe which had alot of wet oil in it , as I need the van to get me back and from work I drove it , the smoking stopped aside from a small amount of black smoke when under load .
I drove for approx 50 miles over afew days , she has started to smoke again but to a far lesser degree .
My question is , does anyone think it is the turbo as I can replace this fairly easily or is it a far more serious engine problem as I don't want to waste money on a turbo if this is not the problem .
Many Many Thanks
Steven
woodymk1
it could be the valve stem seals if it does it after idling :D
bromspaintedstuff
Hi Woody
Many thanks for your reply .
Is it a big job to sort if it is the seals ? , would that cause the fair amount of oil coming through the turbo ?
Steven
Have you reconnected the turbo or has it started smoking again whilst the turbo is still disconnected?
bromspaintedstuff
Hi
I hav'nt reconnected the turbo pipe as there is quite alot of oil coming out of the pipe , I don't want to put this through the engine .
As of this morning she is still smoking alittle when cold and when pulling away from a junction after idling .
bromspaintedstuff
A mate of mine said that it could be the engine breathers blocked , where on the engine would I find the breathers ? so I can check for myself ! , also he said that if the valve rod seals have become hardened instead of broken an oil additive might help the problem as I've been quoted £600 - £700 to replace the seals .
Sorry, I don't know. The turbo could still be leaking oil directly into the exhaust?
j.s commercials
iveco breaker
If you take the black engine cover off the top of the engine you will see the Injecters look to the left and you will see a black plastic box with 10m bolts holding it onto the cam cover
There is a two pipes one goes into the engine and one goes down to the turbo
That's the breather
But I thing it's the turbo
adriano
Just open the oil cap when its running. If the breather is blocked there will be pressure there. Does the turbo have muck play? Im guessing its turbo
bromspaintedstuff
Many Thanks to everyone who sent me information and advice , I'll post an update now as hopefully it may be of help to those facing a similar problem .
I checked to see if there was any pressure coming from the opened oil filler cap with the engine running sand there was , someone had drilled a hole in the cap at some point and put a bolt in it so I removed the bolt so as to act as a crude breather , I travelled the eight or so miles to work with the turbo air pipe still disconnected -- no smoke at all !!!!!!! , filled with confidence I fixed the turbo pipe back in place for my return journey and hey pressto -- no smoke at all !!!!!!!!!!!!!! , I have since travelled around 30 miles and all seems to be well .
I'll keep this post updated .
Steven
darrenm
Did you ever manage fix it
bromspaintedstuff
Hi
Many apologies for not posting an update , the problem was fixed by cleaning the engine breather , she has not smoked since and has been brilliant .
Many thanks for everyones help and advice
Kindest Regards
Steven
