| 75E15 Brake lights; Brake lights staying on | |
| Tweet Topic Started: Jun 3 2013, 08:41 AM (1,737 Views) | |
| AJM | Jun 3 2013, 08:41 AM Post #1 |
75E15 Brake lights stuck on - any suggestions? |
| Tidosho | Jun 7 2013, 08:12 PM Post #2 |
Have you checked the brake light relay? This can stick closed, making the brake lights stay on I can check my service manual for you.I've just had a look. Check the brake switch relay in the fusebox, the relay contacts have a habit of fusing together. Next check the plug to the switch on top of the service brake cylinder? (seen under front panel) Edited by Tidosho, Jun 7 2013, 08:29 PM.
