lights help
Topic Started: Jun 5 2013, 07:59 PM (1,579 Views)
marko0418
hi my lights stopped working at weekend. the parking head light came on when i tried to put side lights on headlights dont work back light s dont work high beam light does work and the dash board doesnt light up (speedo revmeter etc) just a fuse? or garage time!?! i was in the fuse board a day or two before this happened changed the cigarette lighter/phone charger fuse which burnt out so might be my own fault.
its 2006 daily mwb box van 35c
Edited by marko0418, Jun 5 2013, 08:17 PM.
woodymk1
Sounds like light control board on stalk they do fail quite alot i changed mine and about a week later mine did exactly what yours has so in temper i gave the column a good smack and it all started working again and its been fine for about six months now touch wood :D :D
cieranc
Fuses:
7 and 9 are for the stalk unit sidelights and low beams. 10a and 15a.
14, sidelights + number plate lights. 5 amp.
15, sidelights, cluster. 5 amp.
20, you already found ;) . 10 amp.
Relays:
25035, Switching on external lights
That's only good if you understand Iveco's totally random fuse and relay numbering system :D
woodymk1
Jun 5 2013, 08:33 PM
We found with ours the earth had burnt out, not heavy enough.
Pulled the unit to bits, soldered a new, heavier earth in. Job jobbed.
One of our lads is an ex-Iveco electrician, which is handy :)
Edited by cieranc, Jun 5 2013, 08:38 PM.
marko0418
cieranc
Jun 5 2013, 08:36 PM
Fuses:
Relays:
woodymk1
been checking all the fuses and i cant see no broken ones think im doomed brakes lights still work indicators still work just no headlights side lights front and back and dashboard dials
