Engine hard to start when warm; 2.3
Topic Started: Jun 13 2013, 08:35 PM (1,409 Views)
markthelark
Hi , Asking for a friend with a 54 plate 2.3 , not sure what HP engine is.
Says that engine starts first time when cold , but hard to start when warm.
Any ideas please . Someone suggested crank sensor , if so , is it at the rear or front. Also possible cam sensor.
Regards
Mark
cieranc
How do you mean hard to start?
Spins over slowly?
Spins over fast for ages then bursts into life?
Spins over fast and slowly coughs and splutters into life?
j.s commercials
iveco breaker
We have just had same sort of problem it was the crank sensor it at the bottom of the engine near the oil filter
markthelark
Thanks for your reply's. It turns over ok , but takes ages to start .
Will tell him to check the crank sensor first.
Cheers
Mark
Troglodyte
Your sensor may be in the bell housing on the left as you look into the engine bay under the manifolds and a bit tucked away or on the right of the engine just behind the crank shaft pulley
markthelark
Troglodyte
Jun 15 2013, 03:13 PM
Thanks , will pass on the info. Will update when he's changed it.
Mark
