rear brakes binding every so often
Topic Started: Jun 14 2013, 03:41 PM (1,381 Views)
woodymk1
Hi all changed my rear brakes the other day and since then drivers side keeps binding not all the time i cleaned and copper greased everything on reassembly the handbrake lever /arm seems really stiff cable all good the h/b works fine but struggles to release had to stop a couple of time smack it back with hammer then fine for a while then it'll do it again some suggestions on how to sort this would be nice oh by the way its a 35s12 xlwb 53plate thanks in advance woody
hiluxman
I had that with my van recently and i tried everthing to stop it but i ended up replacing the entire caliper and its been perfect ever since.
Only thing is my other one has started doing it now!!
GARAGE & TRANSPORT SUPPLIES
Hi Woody, I had this problem with mine a couple of weeks ago.
I assumed it would be the sliders sticking but turned out to be the handbrake lever not returning.
I sprayed mine between the gap with SAS penetrating oil and then with oil can and with her indoors working the handbrake on and off and me keep knocking the lever back with the hammer each time after about 20 goes at this it started returning fine.
Could be small amount of grit trapped between.
hiddenforests
I had a similar problem, what actually fixed it in the end was to spend about 15-20 mins driving around and literally doing emergency brakes up to about 40 mph, to the point of van skidding and vibrating etc etc, hitting the brakes HARD. It loosened everything up and has been fine since, although van needing tidying afterwards as everything got thrown all over the place lol. Had my MOT on it the other day and passed flying colours after that
If it's the handbrake mechanism sticking that won't make the slightest bit of difference.
Plus it's far safer to sort out on a jack than on the road.
