| Iveco Ford Cargo 120e18 Indicators Wont Work With Trailer; NEED HELP INDICATORS WONT STAY ON WHEN TOWING NEED HELP | |
| Tweet Topic Started: Jun 20 2013, 02:55 PM (1,034 Views) | |
| mhamusements | Jun 20 2013, 02:55 PM Post #1 |
I have just put a coupling on my cargo and have begun to wire the socket for trailer lights works fine till i turn indicators on then they stop working till i unplug the trailer .This is causing major problem as the whole use of the vehicle is to tow ,,Iveco have said its common problem go to front indicators not back this hasn't solved the problem any body out there had similar faults knows what to do please Help !!!!!!!!
Edited by mhamusements, Jun 20 2013, 02:56 PM.
| Troglodyte | Jun 20 2013, 08:09 PM Post #2 |
May be a silly question but what voltage are your trailer bulbs ? Is your trailer socket running through a dropper ? Where have you taken your wiring feed from ? |
