| 2000 daily handbrake mechinism help asap | |
| Tweet Topic Started: Jun 20 2013, 07:29 PM (928 Views) | |
| bsaman001 | Jun 20 2013, 07:29 PM Post #1 |
hi guys, im in need of help asap with my rear calipers, bacicly they were seized so had to strip and clean but now back together as soon as the piston moves out a tiny bit due to brake pedal or moving the handbrake lever around the handbrake lever just looses all bite and isnt getting hold of anything, plus on one of them the plastic clip holding the 3 bearings has shattered. but still the other sides is intact and has the same issue, now i guess there should be something to hold the plates together so the ball bearing plates are always pressed together? the allen screw in the side is in the slot on the pistons plate as should be.. am i missing anything, where is the correct position for the spring and circlip? i cant buy fresh calipers as money is tight plus its getting sold in a few days and just need a working handbrake, thanks guys. |
| bsaman001 | Jun 20 2013, 09:37 PM Post #2 |
fixed! turns out circlip wasnt in the groove but a vice and a few turns and popped in a treat, thanks anyway |
| Spooky_b329 | Jun 25 2013, 08:22 PM Post #3 |
Thanks for the update, useful info
