heater; blower switch not working
Topic Started: Jun 20 2013, 07:51 PM (792 Views)
rdenhomer
heater working but the blower switch no working is the switch easy to replace
Bluebird
Hello there
It's a good chance that it's the fuse blown / burnt out - mine had melted the entire side of the fuse box (!) but was easy enough to bypass with a new fuse and no other damage had been done. If that cures it, I suggest you only use the blower when absolutely necessary to clear the screen in the winter - I found using them for extended periods to cool you in the summer was liable to burn the fuse again - just open the window instead...
Hope this helps
