| 65c17; not starting | |
| Tweet Topic Started: Jun 30 2013, 09:47 PM (1,494 Views) | |
| woodview | Jun 30 2013, 09:47 PM Post #1 |
truck went for 300 km,width no problem.fuel light came on just before parking off.went next day to start,it started but oil level light came on,then switched i switched engine off.went to start after 20 minutes,will not start.pls help to advise what to check cos low pressure oump is not getting power as well as diesel pump and injectors.thx |
| DrRossi | Jul 1 2013, 07:16 PM Post #2 |
they is a low pressure pump in the chassis rail on the n/s, but what you need to do is unclip a pipe at the fuel filter head, get someone to switch the ignition on to check if you are getting fuel up there, if not check the fuse bellow the glove box, it is fused but sorry cant remember which one |
| woodview | Jul 1 2013, 10:18 PM Post #3 |
thank you ,checked all fuses,still no power to low pressure pump or any electronics ie injectors etc.pls help |
| DrRossi | Jul 2 2013, 04:43 PM Post #4 |
will only get power to the pump for about 8 seconds when you 1st put the ignition on until it builds up enough supply pressure to the high pressure pump, then cuts in and out as the vehicle is running. it would be very hard to test for a voltage at the injectors also because it is not running. is they any loghts flashing as you crank or with just the ignition on? |
| Spooky_b329 | Jul 2 2013, 06:54 PM Post #5 |
You should be able to feel the pump running briefly when the ignition is switched on. |
| woodview | Jul 3 2013, 09:16 PM Post #6 |
no fuel comes at any time evev if you pull out the pipe but the injector light is now staying on evan though the key is removed.thanks |
| DrRossi | Jul 4 2013, 04:12 PM Post #7 |
if they is a present fault the light will remain on or flashing for about 5 seconds after ignition is off, you need to get the wiring checked down to the electric pump in the chassis, you could put a contant 12v feed to it (pump does have a + and - on it), do it for a short while just to see if you can get running, dont leave it with a contant feed for to long though. |
