| 75e15 Oil pressure gauge/switch | |
| Tweet Topic Started: Jul 1 2013, 05:43 PM (3,606 Views) | |
| brocksdeene | Jul 1 2013, 05:43 PM Post #1 |
Could anyone help please? I have a 75e15 horsebox that the oil pressure gauge started working on and off and now has stopped. The thing is the low pressure light does not come on, unless the engine is stopped. Are they wired separately? This looks like a sender issue. Can anyone tell me where the sender unit is attached to the engine, e.g. rh or lh side, back front etc, can it be changed with the cab still un tilted (only ask as tilting the cab is a ball ache as involves lifting the luton part etc, etc, typical horse box conversion! |
| DrRossi | Jul 1 2013, 07:05 PM Post #2 |
The oil pressure switch is on the right hand side of the engine, not hard at all to change, unless its a horsebox, sorry, the alternator has to come off, also you have to make sure you get the correct switch and even then sometimes you have to update the edc, the switch has the temp and pressure sensor built in, have had it a few times where its the wiring that is faulty, chase it all the way back to the edc, |
| brocksdeene | Jul 1 2013, 07:11 PM Post #3 |
Thank you. |
