| Smokey 2.3 hpi | |
| Tweet Topic Started: Jul 4 2013, 06:10 AM (1,396 Views) | |
| darrenm | Jul 4 2013, 06:10 AM Post #1 |
Any idea on costs had new injectors new turbo what else should I check |
| markthelark | Jul 4 2013, 09:35 AM Post #2 |
What colour is the smoke. |
| darrenm | Jul 4 2013, 04:14 PM Post #3 |
White but only when engine is cold or if I have been sat in traffic for a while |
| markthelark | Jul 4 2013, 05:26 PM Post #4 |
Could be a number of things. You sure it's smoke and not water vapour - possible head gasket - check your water level. Does the water hose feel hard when engine running/just turned off. Does it start straight away , or does it chug into life ? |
| darrenm | Jul 5 2013, 05:52 AM Post #5 |
It isn't loosing any water and starts first time I think it's a breather problem as with oil cap off there isn't any smoke |
| markthelark | Jul 5 2013, 07:34 AM Post #6 |
I'am not familiar with these engines , I assume they have a ECU on them. Since the problem has a sort of pattern , could be an electrical/ecu at fault. Sounds like a fuelling problem to me. Is there a EGR valve fitted to this engine , worth a try first. Just give it a good clean if there is one. |
