2.3 hpi does it have a egr
Topic Started: Jul 8 2013, 03:24 PM (1,549 Views)
darrenm
I am having a blond day and cannot see where the egr valve is on my 2.3hpi
Not all 2.3 L engines have EGR, in fact, there are few engines with EGR and Oxicat on this generation of Daily.
It is located behind the engine, between the exhaust manifold and the intake. Also, these engines has flowmeter, which is mounted on the hose that coming from the air filter to the turbo.
DrRossi
how old is the vehicle, is it euro 3 or 4, euro 3 doesnt have egr and euro 4 does, there is an egr valve at the rear of the cylinder head on the left as you look at the engine, the is a TVA (throttle control valve) on the right side of the engine and an egr air control valve down by the air filter housing on the left,
what is the fault and what are you checking for?
darrenm
It's a 2007 that has been converted into a minicoach but it was a 56 plate gen 3 old headlights ect
It has just started to smoke when cold or if left ticking over it isn't using oil or water and is still doing the same miles per tank even after 500000km
Attached to this post:
Attachments: image.jpg (56.16 KB)
Edited by darrenm, Jul 8 2013, 06:47 PM.
It is the third generation. Originally built for people tranport, means that it is possible to have EGR.
The defect can be the worn nozzles of injectors, should not be confused with the injectors wich leak to return.
darrenm
No it was built as a van before being converted I have had the injects all tested and replaced as required
If the smoke is white to blue, then the cause may be the engine breather (blow-by filter), or the valve seals or turbo.
darrenm
I replaced the turbo about 25000 km ago and did and also did crank case housing last week as it was a mess and full of carbon
darrenm
Jul 8 2013, 08:26 PM
I replaced the turbo about 25000 km ago and did and also did crank case housing last week as it was a mess and full of carbon and also checked both pipes
Edited by darrenm, Jul 8 2013, 08:28 PM.
I ended with guesswork .... perhaps it is better for you to ask for assistance to a garage.
https://dl.dropboxusercontent.com/u/14168135/denar%20008.jpg
darrenm
My local iveco dealer just say put a new engine in it it only cost £4350 plus vat
