2.8 flywheel remounting
Topic Started: Jul 11 2013, 09:16 AM (839 Views)
Mushion
Hi all
I'm currently changing the clutch and crank oil seal on my 2001 2.8
I've had to have the flywheel skimmed too
I didn't realise that the flywheel has to be mounted back the same way it came off due to the crank sensor
Can anyone tell me how to align everything up so that it goes back together in the right place
Any help would be greatly appreciated
Thanks
DrRossi
i im sure you can only get them on in one position, if i remember correctly 2 of the holes are closer to each other so all the bolts wont go in if you have in the wrong position.
