| Iveco daily 2.3 rocker cover gasket replacement. | |
| Tweet Topic Started: Jul 11 2013, 02:56 PM (1,699 Views) | |
| nslasha | Jul 11 2013, 02:56 PM Post #1 |
firstly hello first post!!! massive oil leak believed to be the rocker cover gasket, I cant for the life of me work out to remove the rocker cover though. Ive got as far as having all injectors out, all the 13mm bolts out and can just about do you have to remove the cambelt etc? if so ill do the cambelt at the same time. |
| DrRossi | Jul 11 2013, 04:38 PM Post #2 |
yes you have to remove the cam belt, time it up 1st, not normal for a rocker cover gasket to leak as a metal gasket , make sure you get the correct gasket as it is also a shim for the valve, euro 3 should be a thicker type metal one with a small rubber insert, euro4/5 ones are different |
| nslasha | Jul 11 2013, 04:56 PM Post #3 |
thanks for the reply. have abandoned ship for the day. 99% sure its the rocker cover gasket as there is pools of oil sat on top of the intake manifold (this thing pisses it out!) I have ordered the cambelt kit and the new gasket to be here for the morning so will be game on! was about to order one of those manuals of ebay but none of the sellers will e-mail me it and with the post it won't be here before the weekend. so jsut excuse me if i ask any more stupid questions ![]() |
