| 35s12 wont start - HELP | |
| Tweet Topic Started: Jul 15 2013, 03:13 PM (1,405 Views) | |
| Fergus | Jul 15 2013, 03:13 PM Post #1 |
Went out this morning and my 35s12 wont start! ligts come on OK but when I turn the keyI get a "click" as if from a relay from the fuse/relay area of pasenger side but nothing else. HELP!
| markthelark | Jul 15 2013, 04:59 PM Post #2 |
If the dash lights dim when trying to start , check the battery. Could also make sure the earth/s are ok , including the end attached to the engine. |
| Fergus | Jul 15 2013, 08:52 PM Post #3 |
Mark,the dash lights dont dim when trying to start ,That is why I said they are OK. Made sure the earth/s were ok , including the end attached to the engine. Seems like something from solenoid to starter TBH. If this had bee a Landy or ordinary car then it would be probably fixed by now, It's just the Iveco wiring/fuses that seem a bit confusing to an Iveco newbie like me! Edited by Fergus, Jul 15 2013, 08:53 PM.
| markthelark | Jul 16 2013, 09:27 AM Post #4 |
Check if there is a wiring diagram in the Tech section. Possibly a faulty solenoid. |
| Fergus | Jul 16 2013, 09:56 AM Post #5 |
FIXED! Wire loose on single fuse for starter below steering column Edited by Fergus, Jul 16 2013, 09:56 AM.
| markthelark | Jul 16 2013, 12:30 PM Post #6 |
You can now be our Forum Auto Electrician !!!! |
| coswurv | Jul 16 2013, 07:32 PM Post #7 |
Fair play to adding a pic, may help people in the future. |
| Spooky_b329 | Jul 16 2013, 07:36 PM Post #8 |
Seconded, Mark
