diff oil seal
Topic Started: Jul 20 2013, 11:51 PM (962 Views)
ashbyspannerman
Has anyone on here replaced theirs? i've got a good leak from the front of the diff, can't feel any play in the bearing, is it possible to replace the seal without fully stripping the diff?
andy19
Hi its an easy job, undo propshaft - diff bolts tie shaft out of the way,then undo large nut holding flange on prise out old seal & replace ( the large nut requires a torque of 500 newton meters) Andy
ashbyspannerman
Cheers Mate, you wouldn't know the size of the 'big nut' would you? mates got an inch drive impact gun
