| cab mount bracket | |
| Tweet Topic Started: Jul 21 2013, 05:21 PM (714 Views) | |
| woodymk1 | Jul 21 2013, 05:21 PM Post #1 |
My 35s12 cab mounts replaced about 6months ago the bracket thats bolted to chassis has worn bolt i've got to replace these one had completly sheared off the state of the roads in sheffield are terrible to be polite but having found these worn and snapped bolts would explain the really rough ride so its out early to get some hardened steel bolts just thought i'd share in case any of you out there have tried everything to make the ride better i would check these as 1 that had worn had lost nearly 4mm to 1side of bolt
