diesel pipe connetor to diesel tank leaking; how to fix diesel pipe connetor to diesel tank leaking
Topic Started: Jul 22 2013, 10:42 AM (780 Views)
R3JOHN
my 65c15 diesel pipe connetor to diesel tank is leaking each time i put fuel or at stationary.Thank
The fuel tank has two couplings: one to flow pipe and the other to return pipe, also has a fill hose and a hose for ventilation. Which of these have leaks.
In some cases it is possible to crack the tank near the metal ring (sump hole).
R3JOHN
Thanks Bazil-S for replied.
Flow pipe was the leaking, especially when I fill in diesel at the pump.
You have to look carefully, if there is a crack somewhere. If the coupling is faulty, then you have to replace the entire pipe, you will not find the coupling separately, as spare parts.
R3JOHN
Thanks Bazil-S
