| Prop shaft bearings both the same? | |
| Tweet Topic Started: Jul 22 2013, 10:50 AM (722 Views) | |
| mfoobar | Jul 22 2013, 10:50 AM Post #1 |
Hi all, I just noticed that the rearmost of the two propshaft bearings on my 35s11 MWB is completely shot. Surprised the MOT man didn't spot it (he did spot a load of other things that I would dispute!). Are the two propshaft bearings the same? And are they the same across the MWB, S and C and 3rd and 4th gen vans? I presume it is a fairly trivial task to unbolt the propshaft and slide the old bearing off and new one on? Or am I going to need to take it to somewhere with a press? -Matt |
