| Only left side flashers working | |
| Tweet Topic Started: Jul 24 2013, 10:35 AM (862 Views) | |
| IvecoWork | Jul 24 2013, 10:35 AM Post #1 |
Hello! We got yearmodel 2000 Iveco Daily, VIN: ZCFC4090005218957. Problem is theres only left side flashers (blinkers) working. Right flashers doesnt work at all, not even when warning blinker is put on, so all flashers should flash. Anyone got same problem? Where might be error? Flashrelay is sounding on when left blinkers on, but when right, its completely muted. Where is flasher relay? It isnt in fuse box :/ Sound hears somewhere under steering wheel. How to change it? |
| Bazil-S | Jul 24 2013, 09:01 PM Post #2 |
Hi, There is a short circuit, the relay is electronic and enter the state of self-protection. Most likely, the short circuit is in tow plug if is fitted, if not then you need to check the lamps. |
| IvecoWork | Jul 25 2013, 09:08 AM Post #3 |
Weird: When i take connector off, and put 12volts to left flashers, it does work, but when i put it to right side, it burns fuse instantly |
