Clutch Oil cover?
Topic Started: Jul 28 2013, 07:01 PM (792 Views)
hiddenforests
Hi all,
inside the engine cab there is the little container thingy that is for the clutch oil, the small one directly in front of the steering wheel, it turns out that mine is missing and has had a larger cap cable tied to it, which I have not noticed til now. My questions are 1. what and where can I get a cap from and whats it called, secondly would having the wrong cap tied on have any effect on the vehicle.
One other question, underneath the vehicle if you look underneath where the transmission/clutch is, on the opposite side of the clutch movement there are two rubber plugs, both of mine were out, any ideas again what these are for or where I can get new ones?? Someone suggested bell housing access grommets but struggling to find any info on these, also dont know if they matter or not or if should replace??
see photo
Thank you !!
Attached to this post:
Attachments: image.jpg (114.83 KB)
Edited by hiddenforests, Jul 28 2013, 07:01 PM.
Pretty sure the clutch hydraulic system is designed as a sealed, non serviceable item. You would order the complete assembly pre-filled and bled and fit it to the van...so you may struggle to get just the cap.
hiddenforests
If its sealed and mine had a cap tied to the top of it, what effect would that be having on it? any ideas? do I need to replace the whole thing or is it ok as it is?
