strange oil leak; 50c 15 with 4140, 43N
Topic Started: Jan 8 2014, 07:22 AM (1,144 Views)
Hillbilly
Hey guys,
I have a question about an oil leak in my van. its always been a little drip every now and then that i thought was coming from the oil return line from the turbo. The last couple of days its got pretty bad (a drip every second) so i thought id have a look and fix it.
I high pressure cleaned everything so i could find the leak. its appears to not leak at all with a cold engine, even while its running, but once its warmed up its not far off a fountain LOL. The trouble is i cant really see where its coming from. it kinda looks like its coming from the engine mount attachment to the block, surely they wouldnt be thru holes?
Pretty much every iveco van i have seen leaks oil round this spot, so i was wondering is it somthing you guys have come across before? Is it the sump?
It is possible to be damaged the seal between the lower crankcase and cylinder block.
Hillbilly
i didnt realise the block and lower crankcase were in two parts. I think that is exactly where it it leaking.
Its looks to be a very big job. is it possible to repair without removing the crank or engine?
Edited by Hillbilly, Jan 10 2014, 06:37 AM.
No, you can not!
There is a rubber seal, which in time becomes brittle and breaks.
The lower crankcase it is half of the crankshaft bearing.
Hillbilly
Thank you for the reply.
Hillbilly
this weekend i pull the engine out and fix the leak. while im in there im doing a front and rear main seals, cam belt and the main bearings too.
Wish me luck :unsure:
muli
How did you go with this?
