Wear sensors
Topic Started: Mar 11 2014, 08:26 PM (904 Views)
MAKES
Are wear sensor the same on the front and rear
my van has the brake light indicator on on the dashboard,the reason I think its a sensor is now and again it goes out when I go over bumps and flickers which says bad connection to me
my van is a 2004 35s12 unijet
cheers
Yes! the sensors are the same, also you can check the wires near the connectors.
MAKES
Mar 11 2014, 09:54 PM
cheers
will get some ordered and check the wires
will post up when I have fixed it ^o)
balbains324
Did you manage to get it sorted? I have the same problem.
cieranc
It's been pointed out on this forum before, these sensors (and the loom wiring for them) are vey thin and corrode easily.
It is sometimes a nightmare finding the cause of the brake warning light!
When we do rebuilds on our 65's, we strip the loom out and replace the brake wear sensor wiring with a much heavier 2 core cable - cures the problems at source.
Also, we found that the sensors themselves are a common fitment, and are available from commercial motor factors in various lengths of straight and curled cable.
Hope this helps.
