brakes; brake fault
Topic Started: May 1 2014, 06:16 PM (816 Views)
rangers
i have a daily 50c11 van fitted with a cherry picker. the brake pedal losses presure when pressed hard .cant find any leakes ,discs are fine pads are fine ,changed servo unit but still no better .can anyone help please .
Pol
Sounds like air in the system, have you change the fluid lately?
If you haven't done a brake fluid change try that you should do it every 2 years anyway.
I have a VW transporter 4 motion and brakes are incredible hard to bleed and get all the air out after doing any brake work and it will function normally until you apply high pressure and pedal drops a bit.
aidan
Hi
is it losing fluid i.e. fluid level dropping ? does it lose pressure with engine switched off or just when its running ? Do the brakes feel feel OK / responsive on the road when driving normally ?r
Aidan
cieranc
All of our gen 3 and gen 4 Dailies do this.
If you hold your foot on the pedal hard, the pedal slowly sinks.
If the van stops fine with a firm pedal, its probably OK. Its fairly common for the pedal to slowly sink if you stand on it hard.
If you notice it sinking during normal use then you are right be investigating it.
