| Key Programming | |
| Tweet Topic Started: May 9 2014, 12:13 PM (1,705 Views) | |
| Single speed | May 9 2014, 12:13 PM Post #1 |
Hi, New to this forum, and new to Iveco's. I have got a 35c15, which only came with one key and no user manual, key code etc. I called my local guys for a price for a key - £69+vat. When i asked about programming it they said they needed the electronic and manual codes on the card to do it. When i told them i hadn't got them they said that Ieco will supply a new card, but want over £300 to do so! Is this correct? They claimed it is not possible to interogate the ecu for the code. Again, is this correct? Would i be better looking at getting a full lock set second hand? Does the central locking and immobilier have a seperate ecu? Many thanks in anticipation of your help guys. |
| aidan | May 9 2014, 12:38 PM Post #2 |
Hi A good auto locksmith will be able to copy this key and clone the immobilizer chip. Aidan |
| Gary Buttle | May 10 2014, 06:37 AM Post #3 |
the key can be cloned so it will start the van but they cannot clone the remote so doors have to be unlocked with the key.As iveco does not trip the central locking when you unlock with the key ,you have to unlock each door individually.My cloned key cost £60.00 |
| BlueBoy | May 10 2014, 07:50 AM Post #4 |
Dunno if anyone has researched this at all, just thought you might want to read up on this system. http://www.obdtool.co.uk/wholesale/ad90-transponder-key-duplicator-plus.html HAVE YOU TRIED THIS.......?? http://ivecoforums.com/topic/8771075/1/ Edited by BlueBoy, May 10 2014, 07:53 AM.
| Bazil-S | May 10 2014, 07:38 PM Post #5 |
Hi, As said above: A good auto locksmith will be able to copy this key and clone the immobilizer chip... plus clone the remote chip. You only have to Google, or make some phone calls, to find a locksmiths with advanced tools in your area!!! |
