| non starter no ecu light on dash | |
| Tweet Topic Started: May 13 2014, 02:12 PM (629 Views) | |
| peterneylan | May 13 2014, 02:12 PM Post #1 |
06 iveco daily no ecu light or glow plug on dash key code flashing non starter |
| BlueBoy | May 13 2014, 06:23 PM Post #2 |
Bit more info maybe? What gen, engine size etc? Owned it long or just bought as non-starter? Got correct key etc? Edited by BlueBoy, May 13 2014, 06:24 PM.
| fern30 | May 21 2014, 11:10 PM Post #3 |
Son has a Vauxhall Corsa, same fault - key code flashing, non starter. Turned out to be the transponder inside the key. Car didn't recognise the key so it wont turn on. Flashing key symbol. Spare key worked fine. Had to get a replacement key. Could be the same? |
