| Gear Change Linkage; Adjustments ? | |
| Tweet Topic Started: May 19 2014, 09:30 AM (1,187 Views) | |
| tomblyth | May 19 2014, 09:30 AM Post #1 |
Hi Guy my 35 12 (51 plate ) which I've had sorned for years is now been converted to a Motorhome but the gearchange is hard ! is there a fix / setup of the linkage that i can alter? and if so how?... Cheers Tom |
| plumber john | May 19 2014, 05:24 PM Post #2 |
Not sure about adjustment but it seems that They all have stiff gear change, as does my 2002 35s11 I recently changed my gearbox oil which has helped but still a little sticky between 1 and 2nd but much better.. After reading the threads on sticky gears I got the recommended oil from iveco dealers. |
| BlueBoy | May 19 2014, 08:16 PM Post #3 |
Hi Tom. Which gears exactly? The 35s12 and others suffer from 1st to 2nd when cold and unless you have the Iveco recommended oil in there you may cause more issues too. Mine was pretty crap until I emptied the cold coffee mess in there from previous owner and put the Urania in there, made a big difference. Also, some owners have taken the gear stick gaiter and housing off and cleaned off the dust and lubed up the mechanism to halp as well. All easy and cheap fixes. If you're experiencing probs in other gears when engine has warmed up then that may well be a different problem though. |
| fern30 | May 21 2014, 06:07 PM Post #4 |
Same here, rough going into second, especially when cold. Visit to an Iveco dealer and a urania gear oil change later..much better. Still not perfect though, a little "agricultural"
