Gearbox oil
Topic Started: May 28 2014, 12:29 PM (1,551 Views)
Tonka
Does anyone know a uk supplier for tutela truck gearlite 75w80
Also for a full change how much would I need ???
Or any other oil that would suit a 2004 daily?
Edited by Tonka, May 28 2014, 12:58 PM.
Without a doubt, purchase it from an Iveco Dealer. I've not seen it elsewhere, although a couple of forum members have found a premium gearbox oil that has met the OE specification.
My gearbox got very stiff and hard to get into gear when cold when a garage just put standard gearbox oil in, I struggled for a year before putting in the Iveco/Tutela stuff and within 15 minutes driving it had transformed the gearchange, very light and no more grinding!
plumber john
How much you would need?
your Iveco dealer will tell you that from your reg plate...
Or, look at the technical download on this forum,
Definatley dealer oil!
Made my box a lot smother...
Tonka
Ok, thanks, will ring tommorow, just thought I might be able to buy online?
yiannism
Hello,
If you want your Gear change and your gearbox to be as good as new..
then you got to consider adding the following brand KENDALL
Read the posts on that and you will understand...
check out also the link below
http://www.industrial-oil.net/conoco-phillips-1051955-kendall-super-3-star-synthetic-80w140-gear-oil-1-quart.html
Thanks
John
Tonka
OK John, but the link is not for UK pockets . :'( :o :-/
Edited by Tonka, May 29 2014, 06:02 PM.
