| route for cable from engine compartment to cab | |
| Tweet Topic Started: Jun 17 2014, 09:51 AM (589 Views) | |
| artybee | Jun 17 2014, 09:51 AM Post #1 |
Newbie first post... Hello. I have a 2006 LWB 35S12 2.3 and am trying to fit a voltage sensing charge relay. I'm happy with what to connect where and where to fuse etc but I'm after a suggestion for an easy and sensible route for the cable from the starter battery to the interior by the driver seat. Thanks in advance for any help. Rich B |
| Spooky_b329 | Jun 19 2014, 09:36 PM Post #2 |
I've drilled through the firewall near the left bonnet hinge to get a 35mm sq cable into the dash behind the steering wheel. More recently I fitted a second relay to provide ignition power to a supplementary towing socket, after removing the glove box I made another hole in the grey grommet around the main wiring loom and got a couple of wires to the starter battery fairly easily. |
| artybee | Jun 23 2014, 08:42 AM Post #3 |
Glove box route sounds less scary. Thanks. |
