| Advise; Options | |
| Tweet Topic Started: Jun 19 2014, 09:27 PM (543 Views) | |
| Leosharpe | Jun 19 2014, 09:27 PM Post #1 |
Hi so I have a 35c11 02 with 105000 on the clock It has a oil leak from the top rear of engine Clutch seems to make a grinding noise although shifts fine The gearbox makes dull tone when in 5th Rear diff is leaking Rear brakes need attention Misfires when cold at 3000rpmbut goes after 30seconds Is this van worth repairing ? Body work is good. |
| woodymk1 | Jun 20 2014, 05:57 PM Post #2 |
In a word yes mine got 350,000 on it and its just having its brakes done |
