| air con compresser seized | |
| Tweet Topic Started: Jun 30 2014, 03:51 AM (743 Views) | |
| muli | Jun 30 2014, 03:51 AM Post #1 |
Is the pic below the aircon compressor as i think its seized up. Is it ok to disconnect it and still drive. Looking at the carhead on its on the lefthand size below the turbo. Edit: Ive cut the belt off. smoke was coming from that pulley ![]()
Edited by muli, Jun 30 2014, 12:10 PM.
| transport121 | Jun 30 2014, 10:59 AM Post #2 |
Hi Can't see any pictures,please try again. My winter job is fixing air conditioning and fridges,so maybe i can help. |
| cieranc | Jun 30 2014, 03:07 PM Post #3 |
If that belt only drives the air con pump, then it'll be OK to run without it. |
| transport121 | Jun 30 2014, 04:00 PM Post #4 |
Hi again Was the belt smoking when the air con was switched on or off. How many wires are there going to the compressor clutch. |
