Location of blower heater case; Blower not working
Topic Started: Jan 30 2015, 11:33 PM (784 Views)
redvanman1
Hi I have a daily 35s 12 05 reg, blower working intermittently , then packed up all together , previous posts suggest removing and cleaning the spade connectors which are located in the heater casing , access Is described as inside the engine bay I have had a quick look but can't seem to identify the actual heater casing can anyone help with specific instructions on where to look .and how it comes apart many thanks
richie7505
Hi I have the same problem, looking for the resistor, did you find it?
Gary Buttle
The resistor for the blower is under the glove box,remove the glove box and its right in front of you
ivecofd
The attachment shows the location of the heat exchanger for the cab heating. The image shows the location for L H Drive. For RH Drive the thing'll be the other way around.
The two pipes to/from the heat exchanger are on the lhs of my vehicle which is RH Drive, they go through the cab/eng' comp' bulkhead. There's a lot of plastic stuff to be removed to access the heater unit which is inside the cab. It seems that to access the cab heat exchanger AC unit, it needs to be done from inside the cab.
Attached to this post:
Attachments: Top_view_of_AC_heater_unit_lhdrive.jpg (27.11 KB)
Attachments: Heat_exchange_location_lhdrive.jpg (39.92 KB)
Edited by ivecofd, Sep 10 2015, 07:48 PM.
