alternator on iveco daily; removing and fitting
Topic Started: Jul 28 2015, 04:42 PM (2,468 Views)
ajplastering
Hi, alternator knackered so have to replace it. I'm use to alternators that are on a slide rail and pull back and tighten nut to tension belt but nothing like this on Iveco. There is a small wheel which looks to take up slack but can't see how as just bolts straight on? Anyway managed to remove alternator by removing this silly wheel.
Now how do you refit alternator so belt is easy to get on and how do you tighten belt?????
Yes they are tricky suckers, if you put spanner on nut of tensioner wheel turn it , this cranks tension spring back allowing to get belt on, nut is captive so doesnt undo, for the life of me sorry cant rember clock or anticlockwise, eitherway I used one spanner on nut then used another spanner jammed into the end of that to give much more length for easier leverage.
basically you need three hands its one of those jobs, a knuckle skinner for sure.
ivecofd
There's some images of the alternator in attachments.
It may be necessary to do more than one reply for them all to be available.
Attached to this post:
Attachments: Alt_brkt_alt_ps_sfw.jpg (32.5 KB)
Attachments: Alt_brkt_ps_sfw.jpg (26.45 KB)
Attachments: Alternator_from_front_ps_sfw.jpg (23.78 KB)
Attachments: Alt_tens_adj_ps_sfw.jpg (43.45 KB)
Attachments: Alt_tens_adj_rbld_ps_sfw.jpg (39.28 KB)
Attachments: Alternator.jpg (132.6 KB)
Edited by ivecofd, Jul 28 2015, 09:08 PM.
ajplastering
sorry, should have said its a 2004 2.8 lt engine
ivecofd
F1A engine is 2.3 ltr.
F1C 2.998 ltr.
8140XX of which there are several types 2.8 ltr. The hp varies from 88 to 141/150.
8140.43C.4 ID/TCA 2.8 ltr.
8140.63.4 PC/NA 2.8 ltr.
There are engines with electronic high pressure injection system 8140.43R.43XX/44XX--------.43B.43XX/44XX --------.43S.41XX------
.43S.43XX/44XX------------.43N.43XX/44XX
and:
Engines with rotary mechanical injection pump 8140.43C.43 XX and 8140.63.40 XX.
In attachments images of Alt belt removal info' which seems to apply to the 8140XX engines.
You'll need to put the two images together the dwgs go at the top of the text.
Attachments: Alt_belt_remv_1_ps_sfw.jpg (72.91 KB)
Attachments: Alt_belt_remv_ps_sfw.jpg (131.46 KB)
Edited by ivecofd, Jul 29 2015, 07:36 PM.
