| Lighting problems | |
| Tweet Topic Started: Aug 16 2015, 01:05 PM (865 Views) | |
| Steevs28 | Aug 16 2015, 01:05 PM Post #1 |
Hi all, Just bought a Iveco Daily locally but have just noticed that none are the dials are lighting up, also having intermittent problems with indicators not working. I've checked all the fuses and they are all good. |
| plumber john | Aug 16 2015, 02:15 PM Post #2 |
Not sure about the dials but the intermittent indicators could be down to dry solder on the indicator stalk circuit board, 'a common problem' Read this from technical download section of the forum.. https://dl.dropboxusercontent.com/u/14168135/Headlights%20flashing%20on%20and%20off_v2.pdf Good luck.. John |
| Steevs28 | Aug 16 2015, 07:37 PM Post #3 |
Thank you John, I'll have a read. |
