| Loss of power; Loosing power injector light on | |
| Tweet Topic Started: Aug 17 2015, 01:10 AM (635 Views) | |
| Whiteee83 | Aug 17 2015, 01:10 AM Post #1 |
Hi all. Hope someone can help me out. I have a 2003 35c13 2.8 daily. I replaced 2 injectors a few weeks ago and ever since the injector light is on constantly. Van has been driving fine but every now and again the van will lose power and injector light flashes. I push in the clutch and let the engine rev drop below 1500rpm and power is restored. This might happen once a week or several times a day. I've had it with several garages and everyone is coming up with different answers none of which are correct. Thanks again. |
| ivecofd | Aug 19 2015, 10:43 AM Post #2 |
35C12 2005 MWB DRW 3rd gen’ crew cab tipper F1AE04 85.3 kw 2.3 cc 16v EDC 16. F1A engine is 2.3 ltr. F1C 2.998 ltr. 8140XX of which there are several types 2.8 ltr. The hp varies from 88 to 141/150. 8140.43C.4 ID/TCA 2.8 ltr. 8140.63.4 PC/NA 2.8 ltr. There are engines with electronic high pressure injection system 8140.43R.43XX/44XX--------.43B.43XX/44XX --------.43S.41XX------ .43S.43XX/44XX------------.43N.43XX/44XX and: Engines with rotary mechanical injection pump 8140.43C.43 XX and 8140.63.40 XX. You may need to know which engine type you have. |
| tuftey | Aug 19 2015, 11:34 AM Post #3 |
turbo vac acuator faulty I had identical same fault if it gets plugged in it will be low boost pressure and it's the waste gate on turbo |
