| Loss of lights | |
| Tweet Topic Started: Aug 24 2015, 07:58 PM (1,067 Views) | |
| andy2703 | Aug 24 2015, 07:58 PM Post #1 |
Hi all 04 daily Recently lost front side lights, tail lights, dash lights and lights left on buzzer.... Not fuses or bulbs. Checked.... Any body any ideas Cheers |
| ivecofd | Aug 24 2015, 08:47 PM Post #2 |
35C12 2005 MWB DRW 3rd gen’ crew cab tipper F1AE04 85.3 kw 2.3 cc 16v EDC 16. Earth point check. Stalk unit. 2 connectors P1 P2 below steering wheel. Lots of info' on forum try search near to top rhs of web page. |
| andy2703 | Aug 26 2015, 07:45 PM Post #3 |
Wiggled pushed and pulled every socket/connection under steering wheel, still no joy. Power is at sockets so I'm thinking stalk??? |
| ivecofd | Aug 26 2015, 08:26 PM Post #4 |
35C12 2005 MWB DRW 3rd gen’ crew cab tipper F1AE04 85.3 kw 2.3 cc 16v EDC 16. The stalk unit can be removed and the unit dismantled. Lots of info' on the forum. Inside the unit is a circuit board with several solenoids on it. Some months ago I changed the wiper solenoid which I got from CPC Farnel for about £2 they are on the internet. The whole unit costs about £180 there are two types see posts by Bazil-s. This info' may not apply to your vehicle. Fuse 9 and 6 go to the stalk unit. Fuse 14 and 15 go to the lights one fuse supplies one side and tother the other. Iveco in their wisdom refer to the side headlight. Flood and dipped lights. Fuse 6,7,8 supply the stalk. Fuse 16,17,18,19 the lights. Fuse 19 goes to the lights and via an electronic thing to the console. The connectors need to be pulled apart (clips undone) and pushed together, rejoined, doing this can make the mechanical connection good again. Edited by ivecofd, Aug 26 2015, 09:33 PM.
| Spooky_b329 | Sep 2 2015, 05:24 AM Post #5 |
Try the common issues section, two refer to lights. http://ivecoforums.com/topic/8938130/1/#new |
| ivecojoe | Sep 2 2015, 08:32 AM Post #6 |
Not being awkward ,where is the common issue articles ? |
| ivecofd | Sep 2 2015, 09:35 PM Post #7 |
35C12 2005 MWB DRW 3rd gen’ crew cab tipper F1AE04 85.3 kw 2.3 cc 16v EDC 16. Schematic: After the stalk unit there is shown a relay 25035 it is not listed nor shown on the relay panel. Power to the cigar lighter, ashtray light, heater controls (lights), radio, headlight alignment, number plate light, front dimension light, multifunction side headlight, multifunction rear light comes from this relay via fuse 15. Power to the number plate light, front dimension light, multifunction side headlight, multifunction rear light, come from this relay via fuse 14. It seems one fuse does one side of outside the cab lights and tother the other. The radio has more than one power source. I have not found the buzzer. Nor the full headlight indicator light. Both of these could be activated by the ECU/EDC 16. Edited by ivecofd, Sep 2 2015, 09:41 PM.
