Taco to speedo change; Changing from a taco to a speedo
Topic Started: Feb 6 2016, 10:16 PM (1,012 Views)
William1973
IV just swapped my taco to a speedo with a clock as I don't need a taco in my camper
The new speedo so about 12 mph faster than it's doing hope someone can tell me how to rectify this thanks
johnr
has your van got the right size wheels fitted?
mark hadley
You needa little box of dil switches to compensate. It is described in an iveco technical note about replacing the tacho. I'll post again when I have foubd a copy.
Glyn
Is this the one?
http://huddersfieldusedgroup.co.uk/image/data/IvecoRecovery/Tacho%20TSB%20353%20DIL%20Swicthes.pdf
William1973
johnr
Feb 7 2016, 11:43 AM
Yes standard wheels twin at the back
mark hadley
Feb 7 2016, 05:46 PM
Wow that's great I'll try and sort the parts thanks for your help
Edited by William1973, Feb 7 2016, 07:58 PM.
trance
Where did you get hold of a speedometer?
Nice to get rid of that tacho!
MajorBlunder
Does anyone know if its a big job to fit a tacho in place of a speedo? I'm planning to use my camper commercially with a trailer behind so will need it. Thanks. If its not too much hassle I might have that tacho off you. :)
William1973
Thanks you your help chaps found the box and new wireing the only thing I'm stuck on is that there doesn't seen to be a connection block as the tacko wires come through the bulk head
It's said you need to disconnect one and fit to another could any one tel me the position and colours of the wires of said block the (brown blue black white ) from gearbox in the male side of the terminal
That fits to female with brown and 2 orange wires
Thanks
MajorBlunder
Mar 22 2016, 07:56 PM
Do you still need that tacho
Edited by William1973, Jan 14 2017, 04:48 PM.
William1973
Glyn
Feb 7 2016, 07:24 PM
Hi has any one done this job tachograph to speedo
I'm really struggling
I've done everything thing apart from shaping the wires under the dash next the wiper motor I've located the male and female connector that are both connected
But the tachograph wires don't have a joint connector
So it goes straight from the clocks to gearbox
In the job sheet it seams to explain the black connector with orange wires but do sent tell you to unplug it assuming it's just the female part
But mines all ready connected
Can anyone please help.
MajorBlunder
Does the tacho still have everything, all the wires and the connection to the gearbox?
