Identify your vehicle.; To help in providing assistance.
Topic Started: Feb 17 2016, 09:56 PM (3,182 Views)
Hello,
This section of the forum includes three models of the year: M.Y. 2006; M.Y. 2009 and M.Y. 2012.
Do not confuse the term of "model of year" with vehicle type, range, or configurations.
There are technical significant differences between these models and often are hard to give proper advice.
As a model identifier it can be used the front grille which has the air intake with different shape.
M.Y. 2006
The front grille with air intakes crossed by two ribs, many call this model "scarface".
Posted Image
M.Y. 2009
The ribs are removed from air intake, remaining only the background honeycomb grille. This model is also known as Eco Daily, by introducing the EEV engines.
Posted Image
M.Y. 2012
The entire front is restyled, providing a modern look and a larger air intake surface.
Posted Image
The identification plate on the front grille, contain type of Daily, engine type, permissible weight, etc..
Posted Image
On the door pillar on the driver's side, there is a silver label that contains some specification of all ECU fitted. You will find the EOL programming data, which is in fact, the date of manufacture. Also, the EDC type, etc...
Posted Image
Use your signature to provide this data, they are absolutely necessary for us, in order to provide assistance.
Use this example:
IVECO Daily M.Y. 2006 - 35S14 VAN, WB 3300, EDC16C39, EOL=2008
Below are some technical data which are absolutely useless, which should be avoided in your signature, or in your topics:
Registration number, shortcuts of wheelbase, as SWB, XWB...; the superstructure type (only if necessary), as Luton box, or panel van, or tipper. Use instead the terms like Cab, Crew cab, VAN, BUS, Kombi,Vendor, etc. Also some owner fitted accessories like the double DIN media, or alloy rims, etc...
Finally I'd like, if is possible for administrator to pin this topic.
Thank you all!
Edited by Bazil-S, Aug 18 2017, 05:40 PM.
TC12
Hi I can't see the pics it is saying upgrade photobucket/p500???? don't know about all this
CambridgeMart
Photobucket has disabled linking to photos from forums unless you pay $399 a year for hosting; it's killed all the photo threads over on a forum I moderate :-(
I have to find a solution for photos hosting. Photobucket is the second host that lets me down...
marcustuck
I used to use TinyPic but it is so busy sending you pop-ups and adverts it doesn't actually work anymore! I have now started to use https://imgbb.com/
TC12
well the robbing so and so's
Its becoming a headache...
Google Photos - all but impossible
Flickr - not easy
tinypic - spammy popups
photobucket - disabled (and the death of many a classis thread...still a good laugh though http://singletrackworld.com/forum/topic/arrrgghh-my-eye )
Imgur seems to be a popular alternative but not checked it myself.
You can attach small files to your forum post, and then take the link and put it between
Code:
[img] and [/img] tags
to get the picture to show up rather than just a link.
Edit: Pinned as requested :)
Edited by Spooky_b329, Aug 20 2017, 06:45 AM.
Bossangel
At the risk of looking dumb I know which model I am and the eol number and the details required. However who do I send these to to find out which one I need?
