cam belt problems
Topic Started: Jul 31 2016, 09:09 PM (466 Views)
mark hadley
I'm doing the cambelt and having a few problems.
1) The cam wheel and the injector one are out by 1 tooth.
2) there are no markings on the crankshaft in the 9 'o' clock position,
so I don't know which wheel is wrong and I'm rather nervous.
the crankshaft shaft seal has a mark at 3 'o' clock
The pulley has four holes (the bottom one lines up with the mark on the seal.)
The pulley has a small notch at about 1 'o' clock that might line up with the cam belt
The pulley has a hole at about 5 'o' clock, opposite the slot on the cog. which does NOT line up with a slot in cambelt cover which is at 6 'o' clock.
Any ideas what I should line up?
The camshaft is aligned at 12 o' clock see the marks, the injection pump sprocket locks with a 5mm drill and the crankshaft hole must be at 6 o' clock.
Posted Image
mark hadley
Thanks, that was reassuring. I also found alignment marks on the flywheel. The clutch housing had a window at the bottom with a plastic plate. The clutch housing had an alignment mark and there was a notch in the flywheel.
I'm puzzled by the tensioner. How can it work if the pulley is bolted to the big stud on the crankcase? Am I missing something?
Also puzzled about how the cover fits over the tensionner pulley.
Thankd
Mark
trance
Mark,
Not sure if you still at this but the crankshaft pulley does not work with the tensioner. There is another pulley which levers through the tensioner.
I use an open end spanner to hold the tensioner off until the belt has been fitted.
Good luck
mark hadley
Understood. It is all done now ad the engine runs, not been out on the road yet though.
I needed a pair of spanners to hold the tensionner back enough.
Yes the tensionner acts on a specific pulley, but this pulley is then bolted in place to the crankshaft stud.
I presume the idea is that at a regular service the pulley nut is loosened to let the tensionner readjust, and then tightened again.
On mine the belt was very loose when I came to it, and only tightened once I loosened the pulley nut. Also, the stepped washers had been assembled the wrong way round which limited the travel.
